Solid Wood Machining
Tigerstop for knotty alder and label printer.
3/21/16
Jeff M
I'm considering adding the Tigerstop with optimizer to our upcut saw. Does anyone have any experience with optimizing knotty alder? Is there much of a savings in material?
Also I'm would like to know how the label printer would work for doors and face frames. I think it would save a ton of time in labeling parts but I worry that removing the labels before the wide belt sander might be worse.
3/21/16       #2: Tigerstop for knotty alder and labe ...
JR Rutter Member
Website: http://harmonicdesignworks.com
I just use a TigerStop as a stop and optimize manually using a printed cutlist and tape measure on the back fence of the infeed. The TigerStop rep told me that there was not an easy way to cancel a cut and add the part back to the list if it turned out to be bad on the back side for example. Like with a knot that looks tight on the face, but is rotted out on the back. We do a fair amount of knotty alder, which is why I asked him about it. Maybe they have changed this by now?
We sort our door part lists from tall to short so that during assembly, the stiles are just used from long to short. Same with the panels. For the rails, we just pencil the length on the top part in the stack to eliminate measuring at the assembly clamp. Even a new employee can work through a big kitchen like this as long as the system is followed and panels are kept in order as well.
He did tell me that people just leave the labels on and run them into the widebelt, where they disappear without a trace. I've not seen it, so don't know if that is accurate or not.
