Solid Wood Machining
Counter Profile Shoe - 5 head molder
3/22/16
1. How often should I use a "counter profile shoe" on the back end of my new/used Weinig Profimat 23E? On most profiles?
2. What determines WHEN when should be used.
3. Weinig has a service they refer people to that looks great, but is a little pricey - probably worth it for a knife I plan to use a lot. BUT, is there a "shop-built" way to make a counter-profile shoe?
3/23/16       #2: Counter Profile Shoe - 5 head molde ...
James Member
Website: http://www.ctihospitality.com
Hey Scott!
You shouldn't really need one unless there's minimal contact with the metal shoe, and you're having problems with chatter.
Most of the time you can just take a piece of the profile you are running and reverse it to use it for a shoe. We have mirror image knives made for all the problem profiles that we run in large quantities. It's much cheaper than buying a nylon reverse shoe, and you can just make some more when you need it.
James
3/23/16       #3: Counter Profile Shoe - 5 head molde ...
Russ
Website: http://www.mr-moulding-knives.com
Scott The link below should help describe how to make a custom pressure shoe while saving you hundreds of dollars from purchasing a custom one. I literally made hundreds by hand and they work just fine.
All the best Russ
Link
3/27/16       #4: Counter Profile Shoe - 5 head molde ...
Thanks for the responses. I think i'll try a couple of these.
