Solid Wood Machining
1987 Weinig P22N Moulding Machine
4/30/16
Fred
Website: http://www.wbwoodworking.com
Running S4S and material keeps walking away from number 2 side head, Could that be due to a dull blade? The problem seems to be intermittent because some work fine, while others are walking away. Any suggestions?
5/4/16       #3: 1987 Weinig P22N Moulding Machine ...
Russ
Website: http://www.mr-moulding-knives.com
Fred Check the alignment setting of the rebate cutter, I have attached an article to help you, others may have more suggestions Good Luck Russ @ MR
Article
10/19/16       #4: 1987 Weinig P22N Moulding Machine ...
Mike Myers Member
The problem you are experiencing is coming from worn dovetails on the casting which raises and lowers your feed beam. You will notice the more downward pressure you apply to the feed system the worse your problem will get. I believe this machine only has one casting which controls the raise and lower of the feed beam. Most machine have two. One front and one towards the rear.
