Solid Wood Machining
Uneven thickness and twisted 12" and 15" ironwood
5/24/16
TCC
I have lots of 12" and 15" wide ironwood. Looks great when they are just cut from tree. But after a few weeks, i find the thickness are highly uneven, one side is is less than 0.5" , and some part is about 2" because they were cut using chainsaw. And the is highly distorted in unpredictable way - twisted, bow, crooked. I need 11" wide 5' long to make coffin top, but can hardly find it very difficult to use. I am totally stucked here....
Please help.
The stock is still wet.
5/25/16       #2: Uneven thickness and twisted 12&quo ...
TCT
Perhaps you should find another supplier - that wood was poorly sawn, so warpage is the least of your problems.
6/4/16       #3: Uneven thickness and twisted 12&quo ...
Chris Hall
Wood degrades when it dries, some species worse than others. The degrade (checking, warping, splitting) can be controlled somewhat by careful drying processes, however some woods are more prone to instability when they dry. That situation depends upon the ratio of shrinkages between tangential and radial grain, and how the wood was cut relative to grain. Also depends upon the condition of the tree's growth and whether it is likely to have reaction wood from growth stresses.
