Solid Wood Machining
Shop Fox knife standards
6/21/16
Alex Hendrick  Member
I'm wondering if anyone knows a source for production standards on shop fox moulder knives. I just got some custom knives in and the bolt heads that hold the knives to the arbor contact the molding and alter it's shape as it's passing through. Of course i'll have to have them remade , I'd just like to have some go no go type info without reinventing the wheel. This would also be helpful as it relates to curved work vs depth of profile. Maybe it doesn't exist though.
6/21/16       #2: Shop Fox knife standards ...
James sarver
You have any pictures of knife can you use just one bolt on knife i have one that i have too who made knife more info thanks
6/21/16       #3: Shop Fox knife standards ...
B.H. Davis Member
Assuming the Shop Fox moulder still uses the same square head as their Williams and Hussy clone that was discontinued the problem is at the shortest section of the knife.
Knives for the Williams and Hussey heads need to be ground at 1 1/2" wide at the deepest cut are into the steel. That would be the shoulder area of most mouldings.
These knives can be sharpened down to around 1 3/8" wide steel in that area but once that small the bolt heads will come in contact with the wood below the bolts. The options are to replace the knives or leave out the bolt in that should location.
Measure your knives at the deepest cut into the steel. If they are not 1 1/2" there that is your problem.
6/22/16       #4: Shop Fox knife standards ...
Thanks Mr. Davis, that is exactly right. The deepest part of the profile is 1.4380" from the back edge of the knife. They are remaking the knife at their cost. It's a two bolt knife so leaving a bolt out didn't seem safe. Are there any formulas for depth of cut vs radius to ensure that your profile will pass cleanly when doing curves ? Trial and error method would be expensive.
View higher quality, full size image (1604 X 863)
6/22/16       #5: Shop Fox knife standards ...
B.H. Davis Member
An alternative to leaving out a bolt is to grind down the offending bolt head so it clears.
6/22/16       #6: Shop Fox knife standards ...
The rare instance that we have had this problem we used button head cap screws in place of the standard hex. The contact seems to only happen on the extreme edges of the hex and the button head caps are 10x the screws that the supplied Hex's are. That said, its only happened on resharpened knives that are pushing the envelope.
6/22/16       #7: Shop Fox knife standards ...
If the contact point is the point on the hex, you can use the socket head bolts as mentioned, knock off just enough of the point on the hex to clear the profile, or have them center the lowest point of the profile between two bolts which may require a 3 bolt knife.
