Solid Wood Machining
SCM Minimax 25" Sander Feed Belt ?'s
6/29/16
John Member
I have a 1998 SCM Minimax 25" wide belt sander that is having some issues with the indeed belt mechanism. The rear drum that drives the belt seems to slip on the shaft keyed to the motor. I disassembled the motor and drum from the machine thinking there would be a key to lock the drive shaft to the drum, but it is smooth. I did locate 2 set screws, but there is nothing for them to engage onto, only a smooth surface. Any help solving this conundrum would be greatly appreciated.
7/5/16       #3: SCM Minimax 25" Sander Feed Be ...
MarkB Member
If the set screws are slipping you could try replacing them with some sharp ones or remove the setcrews and use a transfer punch to center mark the shaft and drill two shallow detents in the shaft for the set screws to register in.
If the shaft spun on the set screws it likely blunted the conical tips on the set screws.
7/7/16       #4: SCM Minimax 25" Sander Feed Be ...
John Member
Thanks, Mark! I was able to fix the problem as you described with some new set screws and drilling small detents in the shaft.
