Solid Wood Machining
End matching and crosscutting flooring from molder
7/7/16
Peter Member
I have been making flooring for about 15 years on my 5 head Weinig, but have never end matched or crosscut/squared the stock here, rather always crosscut in the field at installation.
I make wider width and random width stock up to a 9" face on my machine but in plank style with typically FAS or Select grades.
I don't need defecting, but would like to keep the stock at it's random 8'-16' lengths.
I have never seen how it is done at a full time flooring plant, but would like to learn what to look for for equipment?
I have a few installers, and higher end builders who like what I can produce, but the non squared, and sometimes non endmatched is their hesitation, because obviously it adds to their install time.
So looking for advice to keep my molder a bit busier.
Are there machines that will do this right after/butted up to the molder outfeed?
I am having trouble visualizing how this is done on a moving board?
Thanks for any help.
7/7/16       #2: End matching and crosscutting floor ...
Bruce H
Why not let your fingers do the walking?...
Throughfeed End Matcher for Hardwood Flo
7/8/16       #3: End matching and crosscutting floor ...
Plan on going to Atlanta this August for the IWF Machinery fair. Anyone making any machine of any type will be there, and you can talk to the manufacturers and even kick tires. Fun and cheap research.
Take a few photos of your products to illustrate what you have, and they can help you find the type of machine that will fit your situation.
Just remember that even though they may not have plaid pants, they want to sell a machine, so be careful, and talk to everyone you can find. Once you have learned what is available, you can make a better decision.
Atlanta IWF Show
7/8/16       #4: End matching and crosscutting floor ...
Peter Gagliardi Member
Dave, I do expect to attend IWF, just trying to get as much of a baseline of non sales related info as possible.
Bruce, thanks for that, but I still don't see how that works with a molder that is constant feed. That machine you show is a stop/start jog style of feed. Unless there is some way to stage the speeds with enough lag to accomodate the jog style.
Thanks again guys.
7/10/16       #5: End matching and crosscutting floor ...
red oaks lumber
i have a fruilmac random e endmatcher,love it. we run 6-8,000 sq per day like clock work
7/11/16       #6: End matching and crosscutting floor ...
Fiodh Member
Look at the PMK machine. I know several that use this USA made machine
