Solid Wood Machining
Setting Planer Knives
8/2/16
Joe Wood  Member
Website: http://woodsshop.com/
So I got a new Grizzly 15" planer and was changing the knives today for the 1st time.
When I inserted the new, there wasn't a spring at the bottom holding the knives up a bit, as I'm used to. They just plunked in and bottomed out.
They look perfectly even in the opening, but then what's the knife setting jig for? Am I loosing it or shouldn't there be a spring in the slots so I can press the knives down?
8/2/16       #2: Setting Planer Knives ...
Can't say anything about your Grizzly, but I Have a 15" Jet that uses a hex set screw to adjust the height. You keep turning the set screw until the knife just touches the jig. You do that for both sides and the knife is set. Repeat for the other 2.
8/2/16       #3: Setting Planer Knives ...
Is it magnetic? In that case the knife hangs from the magnet as you tighten the bolts on the head.
8/3/16       #4: Setting Planer Knives ...
Joe Wood  Member
Darn, I don't know if the jig is magnetic Leo, I don't think it is, I'll check in awhile,
I'll also call Griz when they open this morning!
8/3/16       #5: Setting Planer Knives ...
Chuck Rankin
Hi Joe:
We offer a 2 piece magnetic knife setting jig called the MAG SET that sells for $92.50. Here is a web page link with more information. Please call with any questions you may have.
best regards,
Chuck Rankin
Wood Tech Enterprises, Inc.
Our website: www.woodtechtooling.com
P.O. Box 2226
Fairview, NC 28730, USA
1-800-TOOLING (866-5464)
Phone: 828-628-4414
Fax: 828-628-4490
View larger image
Mag Set knife setting jig
8/4/16       #6: Setting Planer Knives ...
Hen Bob Member
I 2nd the magnetic jig. Its the best way I know of
8/4/16       #7: Setting Planer Knives ...
Joe Wood  Member
Yeah this has adjusting screws instead of the springs, I liked the springs better, time to get those magnetic type jigs.
