Solid Wood Machining
Edge Joint Machine
9/26/16
woodworker
Jointer,
Straight rip line,
Anyone please list down all the edge joint machine available in this world...ty
9/26/16       #2: Edge Joint Machine ...
Dustin Orth
What info are you looking for? How they compare in quality of cut? Production rates? Give us a little more info please.
9/26/16       #3: Edge Joint Machine ...
Woodworker
I current use 16" Jointer to joint the edge before jointing 9-10 pieces of 7' X 7" solid wood board together... Recently I have my little finger cut. My Jointer is around 6 feet long with 120mm Cutting circle, very nice, but dangerous to use.
Using Table Saw for jointing wood is slow and not effective, not efficient too.
Any better machines that can replace my Jointer, where accident will never happen even to newbies..
ty
9/27/16       #4: Edge Joint Machine ...
Dustin orth
What's your budget for this? A straight line rip will do what you need but if you are only doing a few boards a day the cost, space taken and power it needs to run, it's not a good purchase. These machines have their own set of dangers, different from a jointer but some situations could be much more costly than just a nipped finger. You could lose an entire hand with one of these if you don't know what your doing. Production wise, this machine can do at least 500 board feet an hour with one person, with 2 people, double or triple that.
9/27/16       #5: Edge Joint Machine ...
A joiner handplane will do the job. It must be properly set up and sharpened, so there is a slight risk of drawing blood, but at least not too serious of an injury. It is best to start with a faster, roughing plane, then finesse the edge with the joiner plane.
This can be a very pleasurable way to work, but hard to do if quantity is a part of it.
For the record, I and many others have used powered joiners nearly every day of our lives and have never nicked a finger. It is not the machine - if it has a guard, then it is the operator. If you don't know proper use, then hire someone to teach you.
9/27/16       #6: Edge Joint Machine ...
woodworker
Thanks Mr Dustin and Mr David. Any 50hz 400 volt straight line rip that is suitable for heavy 7 feet long stock together with adjustable wood router? My budget is around 4-5k usd. Ty
