Solid Wood Machining
Planeing angled 6x6 post caps with PT yellow pine
10/8/16
cabmaker Member
Thinking about making deck post caps. Looks like a pyramid (but only a slight rise- maybe 3/16") Have done in the past on table saw (smaller ones) Hate that though. Thinking about a sled with a permanent shim or wedge so when I put the 7 1/4" x 7 1/4" x 1 1/2" square block on it (and make sure it's held securely) it will plane it to the correct angle- then I rotate and pass it through 3 more times- Has anyone tried this, are there pitfalls or any other safe way to achieve this?
All responses appreciated.
10/8/16       #2: Planeing angled 6x6 post caps with ...
perley bowen
A raised panel cutter on a sharper.
Perley
10/9/16       #3: Planeing angled 6x6 post caps with ...
Duster
Website: sunvalleywoodworks.com
I've done those with a table saw and it is kind of scary. If I had to do it again I'd use my band saw and edge sander.
10/9/16       #4: Planeing angled 6x6 post caps with ...
cabmaker Member
Band saw and edge sander sounds good.
Might try that
10/9/16       #5: Planeing angled 6x6 post caps with ...
You'll get some blowout with the cross grain run in the planer. You'll also get some to blow up when the cap gets stuck between the feed rollers, unless you stack up all of them in the same fixture.
