Solid Wood Machining
Feed roller settings
11/8/16
Kevin Member
I am having some feed problems on an older scmi s520. Can anyone tell me what height the powered outfeed roller should be in relation to the knives? It seems like it may be too low, but not sure. Also seems to occur on one side of the table more than the other. I have adjusted spring pressure but not seen any improvement. Nothing in the manual from scmi. Thanks
11/8/16       #2: Feed roller settings ...
JeffD
If it's the really old S-520 like mine, the outfeed roller is spring loaded, so not sure if height adjustment would be needed? Also if you have the knife grinding attachment you may not want to mess around with height adjustments as it could adversely affect feeding?
I think part of the feed issue may be from the infeed roller edges getting dull from years of use? I have to wax my tables fairly often to keep it feeding well. Have thought about having the infeed roller edges re-ground, but haven't made a move on it yet.
good luck,
JeffD
11/10/16       #3: Feed roller settings ...
Kevin Member
Thanks. I think I got it pretty well set up. Beds were off a bit left to right in relation to the cutterhead, so I started with that. Then, set the outfeed roller at .03 below the knives. It was way too low before, not sure why. Backed the springs all the way off, then made sure they were applying equal pressure to both sides. Double checked the table roller setting, waxed the tables, and it feeds great. I think my serrated feed rollers are worn as well, just can't commit to replacing/resharpening.
11/10/16       #4: Feed roller settings ...
Kevin Member
Just checked, a replacement sectional feed roller assembly from scm, $2,863.
11/10/16       #5: Feed roller settings ...
JeffD
Ouch! That's more than I paid for my planer!
I would think the roller could be re-machined/sharpened....not sure the correct term, but basically have the edges made to grab better. I wonder if it's something a local machinist could do? I may look into it someday, but for now I just keep the can of wax right next to the planer!
JeffD
