Solid Wood Machining
BANDSAW BLADES
11/9/16
CLINT Member
I make big chunky letter on a bandsaw. 3" thick is my most popular product. I also go through bandsaw blades like crazy making these.
I plan on raising my price on these the first of the year to offset. Just wondering if there is anything else that I could do? I currently run a 15" grizzly. Blade I use is a 3/16 4 tpi hook. Rarely if ever break blades, just dull them. I can't really go up in thickness cause I need to get into tight radius.
Would going to a 1/8" help? It would be easier in the corners. Slightly cheaper. Just afraid I would be breaking them a lot.
My saw could use some tuning. Would getting the blade tighter make a difference? What about different guides?
Sometime down the road, I want to upgrade saw. What should I be looking for?
Thanks!
11/9/16       #2: BANDSAW BLADES ...
CLINT Member
BTW, here is an example of what I do. Thanks again.
View higher quality, full size image (720 X 960)
11/10/16       #3: BANDSAW BLADES ...
B.H. Davis Member
Look for a bimetal blade. That will have a carbon steel base with a second, harder metal on the tip edge of the blade blank. The teeth are ground into this harder metal edge.
Lenox is about the longest lasting blades that I've been able to find.
11/10/16       #4: BANDSAW BLADES ...
CLINT Member
Thanks BH. The company I am using now is Morse. Would Lenox be any better? I will check with my tooling place to see what my options are.
11/16/16       #5: BANDSAW BLADES ...
Bruce H
While you are at watch this video on how to tune up your saw. It will make a difference.
Band Saw Clinic with Alex Snodgrass
12/2/16       #6: BANDSAW BLADES ...
KD
When you put a new blade on take the time to "condition" it. Round over the back of the blade with a stone while it is running. Then take the first cut very slowly, take a couple of minutes to go the first 2 inches. Now cut at your normal feed rate.
12/7/16       #7: BANDSAW BLADES ...
CLINT
Thanks guys. I ended up buying a Carter guide which works really well. Some time down the road, I will buy a nicer saw. But for now, this works. Thanks again.
10/30/17       #8: BANDSAW BLADES ...
William Falberg
Website: http://www.falbergsaws.com
I was getting 1.5" radius cuts with the Lennox 3/8"-3TPI that were very smooth but for 1/2" radius turns you'll want a Timberwolf 1/2"-2TPI because you can re-set these blades for wide kerf set angles. They're rough cuts but turn on a dime. Any 1/2"-2TPI blade can be re-set to do this, but Timberwolf starts out with a pretty high set angle already without re-setting.
