Solid Wood Machining
Moulding Miratech (Esterior MDF)
11/18/16
Victor
Website: http://huwoodtrim.com
We operate a standard solid wood moulding shop. And I've been asked to do a large exterior job in Miratec https://www.miratectrim.com/
which is an exterior MDF. These are some S4S and also some custom knife profiles.
Anyone have any experience with this stuff?? I suppose I would have to tool up the same a for MDF... Tho I'm not quite sure what that would be.
Comments??
11/18/16       #2: Moulding Miratech (Esterior MDF) ...
Russ
Website: http://www.mr-moulding-knives.com
Vic
You would have to tool up in carbide, preferably a C3 grade, either a euro style carbide or Bak-Pack style or insert tooling over inlaid carbide which is generally not as good, it takes longer to grind plus inlaid carbide eats up CDX grinding wheels. All of the above options are expensive including the diamond or cdx wheels, you will need two of each wheel a rough and finish of different grits if grinding yourself.
All the best, I hope that helps
Russ @ MR
