Solid Wood Machining
4 sided planer vs moulder
2/4/17
Merkur
We are a smaller company which sells lumber and we want to process rough cut lumber into s4s and moulding. Can someone explain what it the difference between a 4 sided planer and a moulder? We were also looking at Logosol ph360 but it does not seem reliable or sturdy enough. We are looking to buy an older machine made by Weinig or SCM. The boards we want to s4s are up to 23x5 cm. Do we need two machines or just one? Thanks
2/4/17       #2: 4 sided planer vs moulder ...
the google
where are you located? i'm getting ready to list a scmi sintex s4s machine. it does a good job at this - we just cannot find a way to work it into our operation.
pm me if you are interested.
2/6/17       #3: 4 sided planer vs moulder ...
Malte
Website: http://www.logosol.se
Hello Merkur,
Can you please email me more specific about your needs and what you will run? Based on that I can say if the PH260-360 is the right machine for you or not. Also if there are accessories that can make it work even better for you. malte.frisk@logosol.se
2/6/17       #4: 4 sided planer vs moulder ...
Dr. David Rankin
If you are wanting to run mouldings as well, then a good used Weinig or SCM will do that. For the width I would be looking for a 5 or 6 head machine, this will allow you to best run a variety of profiles. Be sure to allow for the expense of installing the machine, dust extraction, electrical hookup , air supply and tooling. Depending upon your location these expenses can add up to be significant.
Be Safe,
Dr. David Rankin
2/16/19       #5: 4 sided planer vs moulder ...
Dave Edgerton
We are looking into this as well and we need to run 4/4 walnut which has been ripped to 2" and final dimension has to be 7/8" x 1-7/8". The question is if the logosol can handle the harder wood or if it better to go with a 5 head moulder.
