Solid Wood Machining
52" Wide Double Sided Planer
2/12/17
Latif TOKUR Member
Website: http://www.tokur.com
Hello All, Does any one have experience in that 52" wide double side planer? If so please tell your comments and its usability instead of a sanding machine.
YouTube Video
4/25/17       #2: 52" Wide Double Sided Planer ...
Woodworker Member
1) Sander can replace planer to "plane" but Planer cannot replace sander to sand.
2) One side process is always flexible than two sides processing. Assume that your two side planer has one side jointing function, another side for thickness function. Then, it is very hard to ensure your stock is flat / straight after the first process (jointing) before go the second process (thicknessing). As the result, you may need to reprocess your stock, that will waste energy, effort and material. Unless your unprocessed stock already in good quality, otherwise i prefer to get a 52" jointer, 52" single side planer. But i don't have you have 52" jointer in this world ;)..
