Solid Wood Machining
Flat Panels
2/21/17
Brandon
I am making an exterior craftsman door out of hickory and I need to make two flat panels approximately 12" x 60" and 11/16" thick. I'm concerned about doing a solid panel glue up at that thickness. Any suggestions / methods on how to approach this?
2/23/17       #2: Flat Panels ...
Are you a professional woodworker? Do you know how to join wood successfully?
You are asking a very basic question, sort of like the guy with a pocket knife asking questions about cosmetic surgery.
2/23/17       #3: Flat Panels ...
Brandon
Thank you for your post, though not helpful. I don't really want to use a solid panel here. I am interested in a veneer with a composite substrate panel, maybe Medex. I guess I was vague in my post so that I could see what kind of responses I would get. Also, no I am not a professional woodworker, but I own a company that sells exterior doors. I am interested in a better way to produce this type of panel. It sounds like you are a professional woodworker so maybe you could help. Any insight is appreciated.
