Solid Wood Machining
Laced splice in a replacement sander conveyor belt
1/26/23
aa
Time has come to replace my widebelt conveyor belt and wondered if there is any downside to having it made with a laced splice? Would be a hell of a lot easier install. Thanks in advance.
1/27/23       #2: Laced splice in a replacement sande ...
voki Member
Website: https://basketballstars2.com
I haven't tried it, but I think replacing it with wool is easy to mess up and break.
1/27/23       #3: Laced splice in a replacement sande ...
Brent Member
Website: http://www.parkhillwoodcraft.ca
I just replaced mine the earlier this week. I got a new continuous belt made - I could see thin material getting pushed down over a splice and thus having a ridge/divot, so I went continuous. It was too bad a job... half day at most by myself. Little sketchy sliding the table out but not impossible.
1/28/23       #4: Laced splice in a replacement sande ...
You are talking about steel lacing, or a sewn splice? The steel lacing is thicker than the belt by itself. It will either stop the sander when it gets to the sanding head, or sand the stock much thinner. I built a home made thickness sander about 35 years ago and used the steel lacing on a rubber conveyor belt. I still used the machine, but often had to wait for the lacing to come around so the stock would not rest on top of the lacing.
1/30/23       #5: Laced splice in a replacement sande ...
aa
Thanks for the replies, it would be a "recessed" stainless clipper hook, laced is probably not the right term. I definitely couldn't risk it being higher as we sand large doors. Just got my quote and it's also $900.00 cheaper for a hook joined belt but for sake of issues down the road probably go with an endless.
Any recommendations for suppliers?
2/24/23       #6: Laced splice in a replacement sande ...
Mike Myers
Been using one for years. No problems at all. The belt was end prepped for a clip so clip was inside belt thickness top and bottom.
6/20/23       #7: Laced splice in a replacement sande ...
Adam West  Member
Laced belts are absolutely inferior to continuous belts. The lacing is much thicker than the belt and it limits how much you can dress the belt to maintain flatness. Imagine years of using a belt that wears more in the middle naturally and not being able to flatten it properly.
I've dressed belts on literally thousands of machines in the last 25 years. The hidden laced belts are the worst. The glue can come loose while dressing and the result isn't pretty.
