problems of tape marks on veneer. -- 0 --
2/19
I am using various dark color veneers and for jointing of two veneer strips (splicing) i am using moister activated (vegetable based glue) tape, my problem is. After sanding their is dark eye catching marks below the tape, i am having great felling that this is due to sunlight effect. if any one knows about new method, new tape, please shear to over cum the problem.
2/20 #2: problems of tape marks on veneer. ...
Deepak,
If it is the sun it would be lighter and not darker under the tape. How are you removing the tape as you may not be getting all the glue off? Is this the smoked oak you ask about in other post? Tom
2/20 #3: problems of tape marks on veneer. ...
Could be a chemical reaction with minerals in the water. Try with distilled water and see what happens.
2/20 #4: problems of tape marks on veneer. ...
Dear tom, we are using water to removing method is wetting tape removing and then drying of ply and then sanding.and you get it its smoked oak.
@Rich i also tried the distilled water but its not working 100%.
2/21 #5: problems of tape marks on veneer. ...
Website: http://www.veneersystems.com
Are you using distilled water for wetting the tape prior to applying it to the veneer? What type of glue are you pressing the veneers with?
2/21 #6: problems of tape marks on veneer. ...
Deepak, Can you post a up-close photo? Tom
2/22 #7: problems of tape marks on veneer. ...
@John yes we were using the distilled water for moisten the tape before pressing, and we are using UF glue for pressing veneer
@Tom yes i got it.
2/22 #8: problems of tape marks on veneer. ...
Dear Tom these are some close up of ebony veneer.
2/25 #9: problems of tape marks on veneer. ...
Deepak,
Try this with a wet rag and a lot of pressure; rub the areas where the tape was at, when the veneer was pressed the tape made an indentation and there is still glue residue in the bottom of it. You may have to change the rag with clean water a number of times. Tom
8/15 #10: problems of tape marks on veneer. ...
Deepak try to get the tape with animal glue. Because animal glue is easier to clean after lamination work. It does not penetrate as much as vegetable glue.
Another thing that I see from the photos that you're using perforated tape. Which you can used it on the lamination face. Meaning that lay the face with tape with glue and plywood. The holes on the tape is good enough to hold veneer. But make sure the tape you're using is not very thick.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
