Laser cutter software
3/4/16
Looking for software that I can use to do marquetry on a laser cutter. Laser came with software. Basic. Very new to this, so any ideas, help would be great. Not a software guru either. So if someone could name something that worked for them. I will research them myself. Boss laser. Using laser works 8 currently.
3/5/16 #2: Laser cutter software ...
I use "Corel Draw" for my laser. For what we do it works fine. It can do so much more than what we do with it.
One of the exporting file formats should work with your laser software.
You may check to see if you can set your laser as a printer. In Corel. Then just print from Corel directly to the laser. I have a Kern laser that is set this way. Three different set ups for different dpi.
3/5/16 #3: Laser cutter software ...
Yup, Coreldraw. Just call Boss for advice. Some use Inkscape for the trace, but no idea if you are creating your own art work, or importing line art.
4/14/16 #4: Laser cutter software ...
Website: http://www.homeeapp.com/
You should research for "Corel" it will surely help you, I was totally satisfied with corel in my case.
