aluminum or steel
12/27/16
Hi all hope your having a great day
I am looking to purchase a hot veneer press
And i want to ask u the diffrence between
aluminum and steel plate if any one can clearify the diffrence between them
What is the best cover for those plate
And do i have to cover both aluminum and steel
and if u can give me your openion to help me choose
Hope you can help me with that
Thank you in advance
1/9/17 #2: aluminum or steel ...
Hi.
We had aluminium plates and then change them with steal plates when they got damaged.
Steal plates are a lot easier to clean and if you are gluing thin veneers the panels are a lot easier to remove from the press.
Damir
1/10/17 #3: aluminum or steel ...
Steel plates will last much longer than aluminum. Aluminum is a soft metal so damaging your platens is much easier. I know, I've used both over the years and have pressed putty knives, razor blades , screws and the steel platens were barely dinged where the aluminum was noticeably damaged . Mylar is probably your best bet for covering and protecting your platens. It's a bit on the pricey side but well worth it.
