Wood NetWork
Subject: Re: Converting lineal ft cost to board foot cost
10/10/13
Ryan Member
Is there a formula to convert a lineal foot cost to board foot cost? If I have an S4S 5/4 board that is 2.125" wide that I paid $.85/lf for, how much did I pay per board foot? Any help with this would be greatly appreciated.
10/11/13       #2: Converting lineal ft cost to board ...
mark
You paid $4.80 /sf, and approximately $3.84 /bdft. Board ft is usually figured before shrinkage or machining though, so it's pretty useless to figure it backwards from actual dimensions.
bdft = sf @ 4/4 wet
10/14/13       #3: Converting lineal ft cost to board ...
Alan F.
BF= 2.125x12x1.25 =0.221354167 BF
.85/.221354167=$3.84 per BF
10/15/13       #4: Converting lineal ft cost to board ...
Gene Wengert-WoodDoc
For pieces that are narrower than 4", we seldom figure the BF, as it is rather meaningless. Instead we use lineal footage or a piece count. That is just the tradition, like it or not.
Is this hardwood? If so, then right now, after drying an planing, the footage for a piece 1' long is
width x length = area
2.125" x 1' x (1' / 12") = 0.177 sq ft
Then, area x thickness is BF. so 0.177 x (5/4) = 0.22 BF (or about 1/4 BF).
[Note that in Alan's posting, there is a typo...
BF= 2.125 x 12 x 1.25 should read
BF= (2.125 /12) x 1.25
but his answer is correct, so it is only a typo.]
For a softwood, we use the nominal size, rather than the actual size when calculating BF. That is why a 1-1/2" x 3-1/2" piece is called a 2x4. So, it is really not possible to calculate the softwood footage because we do not know the nomad width. Should we consider this a 1x3 piece? Normally, a softwood 1 x 3 is actually (after drying and planing) 1-1/2" x 2-1/2", so your piece is a bit smaller. So, a softwood BF is very confusing. That is why BF is not used, but lf or piece counts, as mentioned before.
10/15/13       #5: Converting lineal ft cost to board ...
Alan F.
Gene,
Thanks for catching my error, I assumed from the question that the poster was trying to evaluate what the S4S to size was costing him and knew his 5/4 in the rough cost.
Alan
10/17/13       #6: Converting lineal ft cost to board ...
Dave
As a side note, if you want to figure your cost per Lft to produce the part out of random width hardwood lumber you can use the same formula with a twist. You have to know your yield at the ripsaw and the cost per bf for the lumber. Add those to the previous formula and you know how much the part costs to make. If you think the yield is going to be 68% for instance, then the formula will be:
2.25 (rip size, not net size) / 12 / .68 x 1.25 = .3255 bd ft required to produce 1 Lft of the moulding.
Let's say the lumber cost $1.20 per BdFt.
.3255 x $1.20= .39 Lft cost for the 2-125" moulding.
    Excel Wood Products
