Wood NetWork
Subject: Re: Gluing endgrain heartpine over plywood
2/26/14
Dennis Thacker Member
I could use any help that I can get. I am putting down a floor of 3.5x5.5 endgrain heartpine "tiles" in a basket weave pattern with a walnut border. I was thinking of using a mastic to glue down the tiles and titebond around the perimeter of each tile. There will also be a 1"square of walnut at the juncture of each tile. Any thoughts on a better glue or method? Thanks
2/27/14       #2: Gluing endgrain heartpine over plyw ...
Keith Newton
I wouldn't do any edge gluing, and make sure that your pine is dry enough for this. I would be surprised to find any suppliers that for this species offering it low enough for this use. However, if you go ahead and cut it , you can dry it pretty quickly after it is that short, but they probably will not stay square.
2/27/14       #3: Gluing endgrain heartpine over plyw ...
Thanks for the response. I purchased the heartpine from a supplier. This wood was cut from antique heartpine that had already kiln dryed to 6%.The beam was dressed to 3.5x5.5" and then "sliced" to 3/4" pieces. I have about 1400 pieces and have been storing them for about a year. I would say that 90% have no checks and are still sized at 3.5"x5.5". I have to glue them on the endgrain. I thought that gluing the perimeter with wood glue would help and to the overall stability.
2/28/14       #4: Gluing endgrain heartpine over plyw ...
JeffD
Bostik makes a mastic that works well for this application…."Bostik's Best Urethane Wood Flooring Adhesive".
You need to press the tiles in good for them to get a good bond. And you do NOT want to glue the edges together. It's solid wood and needs to move, trying to keep it from doing so is not going to go well.
I haven't seen it finished firsthand, but from what I've been told they basically sand it out flat and unlike a normal wood floor do NOT vacuum out the dust. Instead they use a sealer coat to seal the dust into the gaps between the tiles, and then apply finish on top. Sounds a bit crazy but the company does them all over the globe successfully so???
good luck,
JeffD
    Excel Wood Products
