Wood NetWork
Subject: Re: Delta Bandsaw Bearings
2/19/20
Hunter Perkins Member
I have an early 80s 20” delta bandsaw in dire need of new bearings on the upper wheel. I have tried using a puller to get the wheel off but have been unsuccessful. Is there a better way to/another way to get the wheel off?
2/20/20       #2: Delta Bandsaw Bearings ...
Daniel Keirstead
Try dousing it with WD-40 and letting it sit awhile, then tapping the center hub with a heavy hammer ( like a 2-pound sledge). The vibrations should help free it.
2/20/20       #3: Delta Bandsaw Bearings ...
I’ll try that again. It has been sitting overnight with pressure and I soaked it in WD 40 again this morning. Do you think any of these screws need to be removed?
View higher quality, full size image (790 X 2035)
2/21/20       #4: Delta Bandsaw Bearings ...
Keith Newton
You might try heating the hub with a torch. The aluminum is a better conductor than the steel shaft, so it may expand enough to loosen the wheel from the shaft.
Yes of course taking the bolts holding the assembly in might make it easier to pull the bearings. If you can't do it on your own, take that part to a machine shop, and I'm sure they can do the job for you.
2/24/20       #5: Delta Bandsaw Bearings ...
Bruce H
You might look here for some information.
Vintage Machinery
4/2/20       #6: Delta Bandsaw Bearings ...
I had to have them press out. Good thing my uncle has a pig press! All in all, it was a learning experience and I will know how to do it next time.
    Excel Wood Products
