Table saw blade coming loose -- 0 --
8/10
I have a sliding table saw that the nut to keep the blade on has loosened enough that the blade starts wobbling.
Nothing has changed besides switching to a sawblade that we have used before.
Any thoughts why it should be coming loose?
8/11 #2: Table saw blade coming loose ...
Website: http://www.curvedmouldings.com
Is the nut side blade stabilizing washer in place?
8/20 #4: Table saw blade coming loose ...
Website: http://www.handrailer.com
The retaining nut depends on surface friction to keep it tight against the washer and blade. Any remaining lubricants from the saw sharpening service may be the culprit.
Strip-able shipping coatings are "oily" as well as grinding lubricants. Did you order any non-stick saw blade coating like "Perma-shield"? This stuff is specially designed to eliminate or greatly reduce friction (which is very good, but not at the hub).
Clean everything up with solvent, paying close attention to the threads of the nut and shaft. Be sure they are clean and undamaged. The nut should remain tight without having to physically "torque it down".
BTW, a saw motor wired wrong and running backwards, will positively spin the nut off in a hot second (no matter how hard it's tightened on the shaft).
Now how ya spose I know that?
8/21 #5: Table saw blade coming loose ...
As vibration can cause loosening, perhaps you also have a bearing that is starting to have too much "play."
Note that the washer used directly in contact with the nut often has an outside and inside. This dished washer, or similar design feature, helps create tension when the nut is tight to prevent loosening. So, maybe the washer is reversed?
8/24 #6: Table saw blade coming loose ...
If your saw has a brake, which is stopping the arbor too fast, the inertia from the blade could be the culprit.
8/31 #7: Table saw blade coming loose ...
Website: http://www.tablesawreviewsgeek.com/reviews/top-tab...
Thank you for the inertia comment. That helped resolve one of my own issues
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
