Wood NetWork
Holzher Panel Saw back grid replacement rails
5/29/14
Fred Wildnauer  Member
Website: http://www.fawildnauerwoodwork.com
I have an opportunity to pick up an older Holzher 1265 vertical panel saw to replace my ancient 1205. My saw is just warn out and the little plastic buttons for panel support are getting very pricey. The one I am looking at has the horizontal grid that shifts up and down to get out of the way when ripping. The plastic rails in this grid are pretty warn. I could certainly make wooden replacement rails but it doesn't look like the rails are easy to remove. Anybody had any luck replacing those rails?
5/30/14       #2: Holzher Panel Saw back grid replace ...
I forgot to mention that the 1265 is a 1994 model.
6/2/14       #3: Holzher Panel Saw back grid replace ...
Kevin Member
I replaced all the battons on my '87 1265. It was kind of a pain but the price to get new holzher battons was more than I paid for the saw. I made new ones out of poplar, worked great.
6/2/14       #4: Holzher Panel Saw back grid replace ...
Kevin: These look great. How did you get the original plastic ones out of the metal channel? They didn't seem to slide out. It appears that if they were pried out, you would run the risk of deforming the metal channel.
6/2/14       #5: Holzher Panel Saw back grid replace ...
Kevin Member
I had to take the entire batton off of the saw to access the screws holding in the plastic piece. Some slid out easily, some needed persuasion. Don't make the mistake I did and make the wood pieces too snug, you will regret it. It was a pain, but worth the savings.
6/9/14       #6: Holzher Panel Saw back grid replace ...
Bruce H
My Striebig (orginal rails now 20+ years old) has wood rails still in very good condition. Plastic isn't necessary, wood works just as good.
6/19/14       #7: Holzher Panel Saw back grid replace ...
Lee Johnson  Member
Website: johnsontechserv.com
Many years ago I commissioned a local mill to make these for us and we have sold hundreds of them. They fit well and don't cut your fingers. Unless you don't have anything else to do but make these then our price reasonable and less than the plastic ones from HH
Contact Chris at 803 789 3105 and she will help you order them.
1/9/16       #8: Holzher Panel Saw back grid replace ...
Joseph D. Christman  Member
Website: IntegrityDesignBuild.com
Lee, I tried going to your website and it was down.
Do you also make rails for the Streibig?
    Excel Wood Products
