Wood NetWork
SCM Planer volt conversion 440v to 220v
2/27/20
Cian Member
I recently purchased a 2001 SCM S630 planer that originally ran on 220volts, it now runs on 440volts. I am looking to understand what is required to internally convert the machine back to running on 220volts.
2/28/20       #3: SCM Planer volt conversion 440v to ...
BH Davis  Member
I think one of two things had to be done to the planer. Either the motor was swapped out or a transformer was installed.
If the motor was replaced then most likely the magnetic starter was also either replaced or altered.
The simplest place to start is to look at the ratings plate on the motor. It will tell you what voltage the motor is designed to run on. If it says 220v then a transformer has been added somewhere. If it says 440v then the motor was swapped out.
3/2/20       #4: SCM Planer volt conversion 440v to ...
bobjh
There should be a label or plate on the motor telling how to connect for different voltages, if possible.
    Excel Wood Products
