Tite-joint fastners
4/27/15
I haven't used these "dog bones" in a long time, but I now have a need and don't want to use the old fashioned type where you need to use an open end wrench. Im looking for the type that you use a screw gun with a "philips" or similar tip to draw it together. I need it to join 3/4" mel tops together.
Anyone have links? Are there any that are low profie that will work in 3/4" mel? I dont care if it hangs down a hair cuz there wont be any obstruction below at the seams
Thx!
4/27/15       #2: Tite-joint fastners ...
Andrew J. Coholic  Member
Website: http://www.joecoholiccustomfurniture.com
Tite-joint are the ones with the ball with several holes that you use a steel pin to tighten.
http://www.rockler.com/tite-joint-fastener
WHat you want are the Zip-bolt fasteners. Yes they make a counter top joiner, but it doesnt use a Philips they use a hex driver.
http://zipbolt.com.au/
I use both Tite-joint, and Zip-bolt. They both have their place but the line of Zip-bolt fasteners are really handy, especially if you do railings.
4/27/15       #3: Tite-joint fastners ...
Thx andrew.
I need to install a closet system's countertops (made an office of cabinets and counters). The counters are 3/4" mel and i plan to biscuit them to keep it flat in addition to the zip bolts
Who do u buy em from? Actual part number?
Thx!
4/27/15       #4: Tite-joint fastners ...
I buy both from Richelieu Hardware, here in Canada. I believe they also sell in the USA. If you search the site they will come up, I dont have part #s on hand.
I think Hafele also sells the Zip-bolts but not every one sells all the different styles.
I know Lee Valley also sells them (and even though they are retail, their pricing isnt all that much more than wholesalers sell them for).
4/28/15       #5: Tite-joint fastners ...
Dan
Hafele also offers the Maxifix Countertop/Work Surface Connector - in two lengths. uses a standard 35mm hole under surface, # 262.87.041 - 65mm long or 262.87.042 150mm long
11.57.pdf
4/28/15       #6: Tite-joint fastners ...
Leo G
Richelieu Link
These seem very inexpensive
Richelieu
4/29/15       #7: Tite-joint fastners ...
csaw
Website: http://www.hofmannjoinery.com
Just so you're aware of it, the Lamello P-system connectors will work in this application (California Closets uses these for countertop connectors).
Lamello Systems
4/29/15       #8: Tite-joint fastners ...
Yes the Clamex connectors are awesome. I bought the machine and have been using it for a while now. They are excellent for melamine RTA work. But will take a few grand to get set up with the zeta machine and a selection of connectors.
4/29/15       #9: Tite-joint fastners ...
Thank you all very much for your input!
4/29/15       #10: Tite-joint fastners ...
csaw
Website: http://www.hofmann.com
Not quite that much, the Zetas start at $1650 and you can buy small boxes of connectors for $100-150 or so. Can also use a 4mm cutter for regular biscuits and special cutter for neat wood patches in the Zeta too.
4/29/15       #11: Tite-joint fastners ...
Joe Knobbe
https://www.fastcap.com/estore/pc/viewPrd.asp?idproduct=45&idcategory=4
https://www.fastcap.com/estore/pc/viewPrd.asp?idproduct=8&idcategory=4
