built in medicine cabinet -- 0 --
6/6
Hello.
Trying to design a built in medicine cabinet:
Where it goes in a cut out in the sheetrock- there are plenty made out of aluminum frames where there is a lip all around which is pretty thin.
How can i achieve this is wood : after all if use concealed frameless hinges the max overlay can be 3/4" so i cannot very well add a lip .
Any ideas or am i barking up the wrong tree?
6/6 #2: built in medicine cabinet ...
What if you cut the sheetrock accurately and trimmed the rock with the plastic or metal channel they sell for capping sheetrock (its a 3 sided piece that slides over the edge ) and then build the box with a rabbet around the edge for the sheetrock. You will have to install it one piece at a time to get it in but then the 3/4 overlay will cover the rock.
If you can have it proud of the wall then make a groove and have the sheetrock insert into that.
6/6 #3: built in medicine cabinet ...
After switching to frameless cabinets years ago this was the only type I still made a face frame for. I believe we used compact Blum hinges with plant on face frame mounts.
Another type of cabinet we make sometimes is a pass through blood draw, simple box with full overlay door, cut hole accurately, install box slightly proud and caulk in.
We have also made box out of 1/2" material with 1/4 x 1/4 added to one edge then run through bander with 1/4" temporary piece, miter fold out of this profile.
Paul R
6/6 #4: built in medicine cabinet ...
Check out Blum inset hinges. We make med cabs all the time with a frame and inset hinge. Just add a shelf at the bottom to act as door stop. Euro hinges of most manufacturers come in full, 3/4, 1/2 and inset overlay. Hope that helps!
6/7 #5: built in medicine cabinet ...
thanks guys.
i realized i posted on wrong forum...
what i was really looking for was the 1/4 by 1/4 idea . with 1/2" sides therefore having a full overlay frameless cabinet.
need to make quite a few of these and this leaves the contractor 1/2" height and width play for his cut out.
ideally i would like more but cant find a hinge that can do more than 3/4" full overlay unless i use salice 40mm cup hinge for thick doors ..but dont want to.
6/8 #6: built in medicine cabinet ...
My Blum rep just showed me a new hinge that can do up to a 1.5" overlay, and opens 92 degrees. It uses all regular mounting plates, you change the overlay by increasing the distance of the boring from the edge of the door. You might want to check those out.
6/8 #7: built in medicine cabinet ...
interesting.
thanks. do you have a part number ?
6/8 #8: built in medicine cabinet ...
the hinge is a 125 degree zero protrusion with a restrictor that reduces the opening angle to 92 degrees. part # 71T750D.
6/8 #9: built in medicine cabinet ...
thanks. real interesting hinge.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
