HSD spindle issues.
6/28/20
Mike nacke  Member
I have a roc tech cnc with a HSD 10hp spindle and a Delta VFD yesterday one of my employees was running some material and the linear brush on our dust foot came loose and wrapped around the bit. He was on the other side of the shop and noticed it and ran over and stopped at the machine. The tool holder and the motor both were very hot. We ran a fan on it and let it cool down and when we went to start it the motor runs and gets up to RPM but it sounds horrible. My first thought was the heat killed the bearings but when the machine is Idle you can spin the spindle and it is smooth as can be does not feel like it has any bearing issues at all. I don't know if it overloaded the motor and burned out a leg or part of the winding? I'm trying to troubleshoot this and serious if the Delta inverter can give any sort of trouble codes to help diagnose the issue? The best way I can describe the issue is it sounds like a bearing is dragging while the motor is running. Like its fighting to spin. It did have a burnt smell right after it happened but not your typical burnt motor smell. Also now that it has cooled off the burnt wire smell is no longer there. Any input is very much appreciated
6/28/20       #2: HSD spindle issues. ...
pat gilbert
It sounds like your spindle needs to be rebuilt by the sound of it.
If you call HSD they will help you with that or maybe help you diagnose the problem.
6/28/20       #3: HSD spindle issues. ...
jerry Member
Did you change the collet and bit
6/28/20       #4: HSD spindle issues. ...
Mike nacke  Member
I didn't think to call hsd. I think the issue is minimal seeing how it does run. Hoping it is a simple fix.
Yes I did remove the tool and holder.
6/28/20       #5: HSD spindle issues. ...
pat gilbert
If it is making that noise it is not minimal
Hopefully their factory is going. IIRC it cost around 3k
6/28/20       #6: HSD spindle issues. ...
Jon Member
It may feel OK spinning by hand, but when it spools up to 16k rpm, it can sound way different.
I had a bearing issue a couple years ago. I could barely feel anything when spinning by hand, but at 16k rpm, it definitely had a bad sound.
6/29/20       #7: HSD spindle issues. ...
Not sure on the little HSD spindles. Is that a cartridge type? If so, those aren't too hard to replace with a new or rebuilt one. I've done a couple of them over the years. Sometimes the bearings might feel okay, but have a bent draw bar or other issue.
6/29/20       #8: HSD spindle issues. ...
BradS
You might want to talk to Atlanta Spindle Services. When I was looking at having mine rebuilt they had a few 10hp re-built spindles on the shelf. You can buy a new shaft kit. There are some that have done it and spoke about it here.
CNC Parts might have a new shaft kit:
https://www.cncpd.com/product/hsd-shaft-kit-a6391h0073b/
6/29/20       #9: HSD spindle issues. ...
Make sure there is nothing up the spindle causing the tool holder to be off centre.
7/13/20       #10: HSD spindle issues. ...
Maurice Phelps
Just my two cents and I repair cnc machines for a living.
I don't do spindle repairs EVER..and that is because its if I don't repair this 24000 rpm-32000 rpm machine and it ejects a tool....that tool will not stop until it finally looses enough energy.
Most of the time if you have a bearing repair, there is something that needs to be done with the draw bar if this is a tool changing spindle...for piece of mind, send it in for repair or if its cheap enough buy another one.
6/2/21       #11: HSD spindle issues. ...
Anusha
Website: http://www.spintec.com.sg
Hi there.
Hope you have a solution on hand.
If no, check this out www.spintec.com.sg.
Based in Singapore, we are well-versed in all make of machine tool spindles.
You may wish to check the attached profile.
20191128_Spintec_Engineering_Profile_V16_2.pdf
20191119_Spintec__Catalogue_2.pdf
    • Palmetto Cabinet Doors
    • Biesse America
    • Template Services
