Subject: Re: Mixing Mohawk acrylic wiping stains and mohawk ultra penetrating w 2K
11/16/18
Mike Member
I keep getting the run around from some of the higher up mgrs with Melisi North America, so as another avenue, I’m asking you guys and gals for help.
I don’t want to invest several hundred dollars into melisi dyes. I will be spraying melisi 2K next week and need to do a dyed finish. I’d prefer to not use Polarian, yet i know for a fact i can mix Mohawk w/ ML’s products without chemical issue.
Has anyone used MoHawks stains and dyes with Melisi’s 2K arcrylic non-yellowing poly and had success?
Several years ago, a company local sold me a Gemini wiping stain (I believe was oil based) and I used Melisi 2K and when one table leaf bumped into anotherC it chipped off a corner of the finish. I’m assuming because melisi 2k and oil stains don’t go together.
I’m sick of the “we only recommend u use our stains and dyes. No crap, so they can make money off of it.
I think melisi would sell so much more product if you didn’t need a different thinner and catalyst for EVERYTHING.
1/15/19       #2: Mixing Mohawk acrylic wiping stains ...
Jay Billiet
Just mix up a small sample of urethane & Mohawk dye stain &/or acrylic wiping stain. With a dye concentrate you would use less dye with the urethane.
If you’re just putting the urethane over the stain, as long as the stain is dry, I don’t think you would have a problem. When in doubt just finish a small sample, big enough to get a good test, and see how that works out. If the sample panel doesn’t have any problems, run-it!!!
Hope this helps you
1/15/19       #3: Mixing Mohawk acrylic wiping stains ...
Mike Member
Thx Jay, but the job is done.
I had to buy Melisi dyes....unfortunately, because of the high &#128176;. It turned out very well
