quarter or rift sawn -- 3 --
9/30
Website: http://www.innerwood.com
we have a debate going on about the veneer on a door and I wondered if some of you could weigh in with your expert opinions. The door is supposed to be quartersawn White Oak and I think this is rift sawn Red Oak. The door has a clear finish on it no stain. The lumber I show on the door is White Oak; the long piece is unfinished and the small piece has a clear lacquer finish. thanks for your comments. Dan
quarter_or_rift_sawn.pdf
rift_or_quarter_sawn.pdf
clear_finish_on_both_pieces.pdf
9/30 #2: quarter or rift sawn ...
Rift White
9/30 #3: quarter or rift sawn ...
Its definitely rift. The lighting in the pics makes it hard to see anything else other than minor color. I would expect it to be darker if it were red oak.
qtr white is one of my favorite woods. Rift sawn red is one of my least. It reminds me of a Formica laminate.
9/30 #4: quarter or rift sawn ...
There are three choices---
flatsawn (also called flat grain and plain sawn)
rift sawn
quartersawn
For hardwoods without ray fleck (ray fleck is the various bands you see on the third photo on the right side), one might define the various grain patterns by the angle that the annual rings make wight he faces of the piece. One common definition is 75 to 90 degrees is quartersawn, 45 to 75 is riftsawn, and 0 to 45 i flatsawn. Of course, one piece can have different angles and so might have two different grain patterns and so then what do you call it? Then, some people think that there are only two grains---flat and quarter, with 0-45 and 45-90 being the division.
With lumber that has ray fleck, however, the widely understood definition is that--
quartersawn shows the ray fleck pattern quite clearly,
riftsawn shows the straight lines of the growth rings, rather than the cathedral grain pattern of flatsawn, but has no fleck.
flatsawn has the annual rings making a cathedral or "V" shaped pattern.
Further, when grading lumber, the clear area used to establish the grade, if quartersawn, must show the fleck on 80% of the area (or similar).
Regarding the pictures: The first one is 100% rift. I cannot tell if it is red or white. The second one, the light colored piece is 100% quartersawn. The third one has quartersawn on the right half, and some on the top left, with the bottom left being more rift (no ray fleck).
The rays in white oak tend to be about 1-1/2" high while red oak are often 3/4" or shorter. The height of these rays in the pictures is quite short, so I would guess that they are red oak, but ray size alone is not the best guide. The best guide is the frequency of the large pores within each growth ring. Note that not all white oaks have plugged (or occluded) cells. Not all white oaks are pale in color and not all red oaks are reddish.
Someone buying quartersawn or quarter grain veneer would have the expectation of seeing the ray flecks on 80 to 90% of the faces.
9/30 #5: quarter or rift sawn ...
Definitely Rift. Anyone claiming this is quarter sawn is either a rookie or a swindler. Whether it is white or red oak is more difficult to tell.
10/1 #6: quarter or rift sawn ...
It certainly has the "rift look", but I believe it is actually what are called "bastard quarters". It is a very common practice in the veneer industry to cut the "quarters" off the sides of plain sliced veneer when you get down into the middle of the flitch and there are too many knots/defects to use it as A or B grade plain sliced. I see the "bastard quarter look" in that door. Most people can't tell the difference, but I have seen "bastard quarters" used for many years, in thousands of faces, and I see very subtle characteristics that point to it. So I am reasonably sure it is neither true rift nor true quarters.
I'm not going to get into the whole supplier/customer communication thing on ordering veneer, but next time specify "heavy flake" in your quarters and whether it is true quarters or bastard quarters, the veneer company will know what you are looking for and can provide that (or should). Just remember that true quarters are a more expensive product and you will pay a little more for them.
10/1 #7: quarter or rift sawn ...
Almost forgot ... it's White Oak.
10/1 #8: quarter or rift sawn ...
I'll go with Gene on this one. 1. Rift, 2. Qtr, 3. both.
There can be no line in the sand when it comes to definitions of this sort. Each slice will be slightly different than the next one. If you took half a log and simply sliced it from the center out, the first slice would likely always pass as qtr, transitioning to rift then to flat. @ what point everyone would agree the transition appears probably varies a lot.
Red or white? Get out your microscope.
10/1 #9: quarter or rift sawn ...
Thank you, I very much appreciate the responses to this post and feel that we have clearly settled the question that the door is rift sawn. I know that determining if it is Red or White Oak is much more exacting and if this had been quartersawn the flake size may have helped determine this. This project has a clear finish on all of the wood so we will have to specify the white range of White Oak.
This is one of five White Oak jobs going through the shop right now and it has been a challenge to be so specific on the veneer selection and have learned to make NO assumptions.
These threads are certainly a wealth of knowledge and experience.
Thanks again, Dan
10/1 #10: quarter or rift sawn ...
Ang Schramm in his book "Hardwood Plywood and Face Veneer" restricts (p. 36) the term "bastard quarters" to a specific case when slicing veneer from near the center of the log with juvenile wood in the center of the veneer sheet which is clipped away, leaving two narrow pieces. If they show ray fleck or flake, they are sold as quarter grain. If there is no fleck or flake, then rift.
However, quarter and rift can be obtained with other slicing methods and then would not be called "bastard quarters." Again, the distinction between quarter and rift is the ray fleck or ray flake pattern.
You can tell the difference between red and white oak using sodium nitrite 5% in water. If the color is dark, then white oak. Works on wet or dry, warm or cold, and is 100%. Sodium nitrite can be made by the local high school chemistry teacher or even a pharmacist, or bought on EBAY, but do not keep an unlabeled bottle around at the workplace--OSHA rule. Just make enough for the present use.
Red vs white technical article
10/2 #11: quarter or rift sawn ...
Exactly correct, Gene. The straight grain on either side of plain sliced veneer are called the "quarters" and when removed from the heart deep in the log, they are called "bastard quarters". If they have no flake, the veneer company should sell them as "rift", with flake as "quarters".
The door company probably didn't specify (or know?) that their customer wanted heavy flake in the quarters (it can be specified in light, medium and heavy flake) and if their veneer face buyer didn't know and went with the cheapest available "quartered" face (to achieve a lower cost), they would get "light", or in this case, virtually none, which shouldn't happen, agreed.
To me this is entirely a case of mis-communication. An order to a veneer company specifying "quartered White Oak" only communicates half of the spec, it doesn't address the most important characteristic in this case, that the end customer expected "heavy flake". That's not an automatic, because most customers (in my 40 years of experience) don't want heavy flake (because of glue bleed-thru, sander tear-out and finishing issues, aside from aesthetics).
What I am getting at is that if you want specific characteristics in your veneer, you need to communicate that clearly in your order. I'm not trying to criticize anyone, people don't know what they don't know and that probably applies to
all parties in this case. The customer expected one thing, the door company wanted to give them the best possible price and therefore veneer company went with the lowest cost veneer, which in both rift and quartered is always "bastard quarters". Should there have been flake in that quartered face, yes absolutely, but is it reasonable to expect the veneer company to utilize heavy flake without some communication of that fact, not really, again most customers don't want that effect, especially in doors (as opposed to say fine furniture).
There are a few of us "old timers" around yet, and we know and understand the questions that need to be asked in order to give the end customer what they really want. Just trying to do my part in educating the next generation of veneer specifiers. Remember that every single veneer face ever made is different from every other face, it's virtually impossible that two faces are "identical". So to expect to get exactly the "look" you want, you need to be very specific in communicating your expectations.
3 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
