Light weight panels for laminate -- 0 --
12/31
Doing a residence that is primarily plastic laminate throughout. Have 2 1/4" thick end panels at most cabinet runs that will go floor to ceiling (10').
Does anyone have a source for substrate material other than mdf or particle board?
Really need to cut down on the weight and still retain stability.
1/1 #2: Light weight panels for laminate ...
Make torsion boxes with 3/8" or 1/2" thick faces, solid edges and a core grid of some type to fill the void. Then add the laminate faces bad edges. We call the fillers egg crates. We don't use PLam, but can put these in the vacuum press with a bit lower pressure and get great results with wood veneers, or veneer first, then make into torsion boxes.
Hollow core residential doors are torsion boxes - light, stiff, and reliable.
1/3 #3: Light weight panels for laminate ...
What David said. I will add that whatever you use to infill your torsion boxes (we use a honeycomb product) needs to be perfectly flush or you will end up with telegraphing out of the vacuum press. To combat this, we generally send our core through the wide belt prior to veneering/laminating.
1/16 #4: Light weight panels for laminate ...
Laminating the floors takes lot of efforts, I have recently installed laminated wooden floors for my office interior, these are easy to clean but needs some more cover to protect its shine for which I have added a carpet from the hotel carpet manufacturer , they have good carpet installation and maintenance services.
Click here
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
