Corner cabinets
8/28/18
It seems like it takes forever to make the parts and build a corner cabinet. I find the edgebanding to be so painful. Is it just me, I try to be a perfectionist but some of these corner cabinets donít look it. What is everyone using for adhesive on the edges. We use the pvc edging with the 3M 20 spray from Richelieu and then install edging and clean it up with a sharp chisel. The inside corner has the radius from the cnc, we just leave the curve there.
Just wondering what everyone else is doing?
8/29/18       #2: Corner cabinets ...
JM
We do exactly what you do. Parts off the CNC, then spray 20, then PVC tape and leave the radius in the corner from the CNC.
Its a pain in the butt, and I can offer no help, only sympathy.
8/29/18       #3: Corner cabinets ...
keelhauled Member
Exactly as you guys. Parts off the CNC and leave the inside radius.
We have a small portable edgebander for external corners and we run a strip of edging long enough to to do the shelves through it to apply hotmelt to the edging. We stand the shelves up in a vice and apply the pre glued edging with a heat gun to reactivate the glue and trim flush and radius.
Job done!
8/31/18       #4: Corner cabinets ...
Steve Juhasz  Member
Website: http://www.centrestreetmillwork.com
We no longer build this antiquated and silly configuration. Just start building blind corner cabinets. There is far better hardware available for them, and they are much easier on the fabricator. Lets face it, customers don't say, "In my new kitchen I want a corner cabinet with lazy suzan and 36" long sides with 12" door."
