optimizing saw -- 1 --
12/1
I'm wondering about the claim by manufacturers of optimizing saws that we can downgrade our material purchasing a step or two from select lumber. We make entry doors and require stable moisture content and wood that is virtually 100% free of defects. Can we use a lower grade of material and still have the stability we need for doors?
12/1 #2: optimizing saw ...
The grade of material should have nothing to do with the moisture content, it is either dried properly or it isn't. I wouldn't accept ANY grade of lumber that isn't dried properly.
The difference will come in when you try to get your components out of the lumber. You don't say what length/width you need, but if you look up the NHLA grading specs, it will tell you what to expect from each grade. If your length/width requirements can be met with something less than "select & better", then give it a try. But don't expect to get seven foot clear lumber from No. 2A grade.
12/2 #3: optimizing saw ...
Couldn't you buy a bunk or two and manually defect it? From that you could determine the yield. It would be slow and ponderous but worth the effort. You would hope the software the the system could do a better job of optimizing the material.
12/2 #4: optimizing saw ...
I would imagine the benefit being a bit less in an operation using larger parts. You would have to have the need for all the low grade and be moving enough volume to use it. Long, thick, clear, solids would seem tough to strip out of packs of #1 or #2. Just my guess.
1 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
