3mm pvc corner finishing -- 0 --
2/5
Can anyone tell me how to finish corners as shown in the picture. It's 3mm pvc from Doellken.
We just got this new bander and it's all dialed in but I'm not sure what method to use for finishing.
Any help would be appreciated.
2/6 #2: 3mm pvc corner finishing ...
If you are going to do a lot of 3 mm, you would be well served to see if you can add a corner rounding station.
I did not have one, and as a result I did not do much 3mm. I shifted to 1mm and still had some handwork for doors and drawer fronts that I dressed with a Betterley air file set up just for that.
For 3 mm I used a laminate trimmer with a 1/8" round over bit adjusted just so. Whenever possible, stack (horizontally - pieces on edge) enough same sized corners together to support the trimmer base. Rout the edge on the assembled stack and then push individual pieces out just enough to trim the corners while keeping the trimmer base supported by the collective parts.
Hopefully someone can share a better process!
2/6 #3: 3mm pvc corner finishing ...
I use a stand alone corner rounding station. I have a Brandt but Holzher also makes one. At the time it was an additional 20K to get added to my bander order, a stand alone unit was 10K. Now, I'd pay it to have it on my machine as it would save having to do it.
2/7 #4: 3mm pvc corner finishing ...
We use a 3mm round over bit in a small hand held router. Don't do much 3mm. Try to find a used round over machine as others have suggested.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
