RITTER R26
6/25/15
Iain Lowrie
Website: http://studio-bianco.com
does an R 26 (dual line boring machine) have an alignment pin to place in last bored hole to set the next set so new ones are exactly spaced. In an R46 they are clearly visible. I cannot detect one in any of dozens of photos I have searched.
thank you in advance.
This question will be moot after tomorrow.
6/25/15       #2: RITTER R26 ...
Jim Herron
I had a older R46 (flat belt drive) that had pnuematic pins.
I had a Gannomat with long back fence and gravity stops set to extend the bore line.
Much, much better accuracy and foolproof setup.
6/26/15       #3: RITTER R26 ...
harold morantz
i have a detel 44 spindle model that has pins,but also has flip stops. As someone else mentioned, pins are not as accurate. If the machine has the place for extension arms, it is worth every penny to get them with some flip stops. We can drill an 84"closet side in seconds. Harold,
