Question for Dennis
6/10/20
Al
Hi Dennis,
A few months back I asked about blind corner hinges. I finally installed project yesterday. I used 2mm plates with pre mounted screws that has cam for lifting doors vertically. These doors are 77” tall, all looks great but have one door that needs to go up about 1/16”. Any Salice plates that will give me a little more adjustment vertically? I used 4 hinges per door.
Thank you,
Al
6/11/20       #2: Question for Dennis ...
Hi Al,
All Salice plates are height adjustable +-2mm. If there is any adjustment left on this cabinet, try starting with the top hinge, adjust that up then work your way down adjusting the rest of the hinges.
Dennis
6/11/20       #3: Question for Dennis ...
MarkB Member
If your maxed out on the vertical cam on the plate your only option is to pull the door, remove the plates, dowel/plug the holes, and re-drill/mount the plates higher. It would seem if you have one door off by 1/16" you either bored the door or drilled the box off to begin with.
