CNC MDF shaker doors advice -- 0 --
2/19
As simplistic this may soud, Looking for some experianced advice from one how actualy do or did MDS shaker style doors on a CNC.
I know the basisc, rout the pannel to make the resess part !
BUT....there’s more to it !
What’s exectly the routing steps & cutting strategy to make a nice flat center and....noce crisp inner corners ?
Then, before painting, there’s the routed marks, as little the may or could be, has to be sanded ?
Just an all & all advice from an experiance one to make this....more efficienat and possibly...proftible, as there is just to many one “dumping” this style / type, I’m requested to make for a Kitchen ...;0( !
Thanks, Rob
2/19 #2: CNC MDF shaker doors advice ...
YOupss....sorry for all those typo mistakes !!....English not my mother tongue +...did it a little to fast from of my tiny tablet...sorry, but on the other hand, I think it’s still...understandable ;o\\
Tks...
2/19 #3: CNC MDF shaker doors advice ...
The quality of the MDF is critical.
We have tried lots of stuff, but ended up using only Plum Creek.
Diamond tooling
2/21 #4: CNC MDF shaker doors advice ...
Anyone ever did such type of recessed / bottom cleaning ( call it anyway yu wish) work with CRISP inner cornering out there,
Anyone ??
Care to share how ??
2/21 #5: CNC MDF shaker doors advice ...
One answer is to make a two pc mdf door. First cut out the frame and dado the back side from 3/4 material . Then cut the Panel using 3/8 material with 1/8 dado so when inserted into frame you will have that 1/8" reveal in the back of the door. Now you will also have a balanced panel less likely to warp
2/21 #6: CNC MDF shaker doors advice ...
Thks Paul.....but NOP !!...it has to be out of one pieces only !!
2/21 #7: CNC MDF shaker doors advice ...
2" tool in the pocket, 1/2 on the inside perimeter of the pocket 1/8 on the inside perimeter of the pocket.
Done.
2/21 #8: CNC MDF shaker doors advice ...
Dropout....if a paint base coating is applied after, say white, then some clear coat, do you bother sanding the 2nd & 3rd tooling makes ( if ever)??.... ( those form 1/2" then 1/8")
Tks
2/21 #9: CNC MDF shaker doors advice ...
I use a 1 3/4" diamond for the field, then a 1/2" up spiral for the perimeter inside, then an 1/8" in the corners then I use a small beading bit to break the inside edge. We use plum creek HDF. You have to be very careful not to leave sander marks when you sand the panel inside.
Double coat your primer. We do a wet on wet coat with conversion varnish primer.
3/2 #10: CNC MDF shaker doors advice ...
Not a fan of MDF doors, each to their own. If you have to do this though don't fuss with pocketing perfectly, it will always have some lines and require hand work that way. Pocket it out and make an insert piece of MDF to slip in place, glue it in place and the filler will make up a nice paintable inset face. 1/8" mdf works well for this.
3/2 #11: CNC MDF shaker doors advice ...
Thks Bill....the problem I've been with this alternative, is some client "hate" the back side look, they rather have the smooth no cut backing when opening the door !
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
