loading 5 axis program to holzher cnc
10/25/17
Ian Member
I have been using our 5 axis pro master to run 3 axis programs with no issue, but today I tried to load and run my first 5 axis program, and got an error that stated -():
(DINISO CALL .hop): Easy Snap Z is not available on this view. (Editor :8). I was not able to load the program to the table. Rechecked the program and all work planes are oriented properly, and everything seems to be correct. What am I not doing correctly?
10/27/17       #2: loading 5 axis program to holzher c ...
Marek Skotak
Website: http://www.cadcam-softcz.cz
Hi,
i do not know all your program. But in a Holzher (also on a other Wodworking machien) 5 axis program by using ISO programming is not possible see in a editor. So for a 3 axis machinining you use NC hops objects and these can be view in a editor and also on a table but Call DIN ISO is call only ISO command which NC hops cannot view. Same is in a Homag, Biesse, Felder ....
10/31/17       #3: loading 5 axis program to holzher c ...
Ian Member
I use alphacam to do our drawings, and I have been outputting finished product to NC Hops ad running, mind you only 3 axis style programming though. The drawing displayed in the preview box in the machine still looks like an Alphacam drawing.
NOW we have figured out how to make a couple of 3d 5 axis programs, and the machine will not let me load them, I get an error that states( DINISO_CALL.hop):easy snap z is not available on this view.(Editor:8)
The tech at Holzher said I need to reference the start point of the material, but the screenshot he displayed for me was a picture of the NC Hops software. I do not know where to go next, as I have basically just posted out of Alphacam for ny programs.
