Orange Peel -- 0 --
5/8
Website: http://www.dreamkitchencrafters.com
I started spraying pre-cat lacquer last fall when the temperatures here in St. Louis were cool. I thinned my lacquer with 25% lacquer thinner and achieved good results. Now that the temperatures are higher I experienced some orange peel. I have never used a retarder but it looks like I will now have to do so. My question is two-fold: 1. How do I mix the retarder and how can I get rid of the orange peel? By the time I obtain some retarder the initial coat will be approximately 24 hours old. Will the application of more lacquer with a retarder in it sufficiently melt the underlying layer to level out the orange peel and if not what can I do to eliminate it. I am spraying 2 large refrigerator panels.
5/9 #2: Orange Peel ...
What are you spraying with you may not want to thin so much if the thinner is a hot one it maybe drying to fast try a slower thinner ask you supply you probably need to sand out the orange peel .
5/10 #3: Orange Peel ...
Another coat will probably not level the current orange peel. Block sand with 320 grit. You can get different drying rates of lacquer thinner. Go to an auto paint supplier if necessary. Better look at nozzle size and pressures for the viscosity you are spraying.
5/10 #4: Orange Peel ...
Orange peel means that there is insufficient material coming from the gun. Check to see that you are putting a sufficient wet coat down and add retarder at 10% to help it level out.
5/10 #5: Orange Peel ...
in spraying additional coats, be sure you do not exceed recommended dry mil thickness or the lacquer can crack. That is only more good reason to thin the lacquer even more than 25%. I wouldn't be afraid to go to 50% since you have established the film thickness you need and now you just need an additional coat that will level out better and establish the sheen you want.
I would scuff sand to assure good adhesion and to help level the orange peel. If there is a slower thinner available from the manufacturer I would get some and mix a fresh batch. Avoid standard retarder (butyl cellusolve)only as last resort. It can be hard to dial in how much and too much can affect the cure and sheen.
Manufacturers are moving to high percent of acetone in their lacquer thinner blends in order to stay in compliance with voc regs. Acetone is an extremely fast solvent and thus works against good leveling. Its getting very hard to find a lacquer thinner that is not heavy in acetone, but they are around.
5/12 #6: Orange Peel ...
I quit using lacquer thinner years ago as
a thinner only as a cleaner for my guns.
Most all the lacquer thinner now is
reconstituted junk.
I now use urethane reducer to thin my lacquer with, as suggested to me by a
chemical expert who knows his stuff.
It has worked much better.
It can be had at any car paint supplies store. And comes in various dry speeds.
6/8 #7: Orange Peel ...
Thanks to all that responded. I discovered the problem was too light of a coat; I was spraying a 1 or 2 mil wet coat. When I increased it to a 4 or 5 mill wet coat and eliminated the thinner things worked out well. Thanks to all that contributed.
Tom
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
