Re: First Big Wall-art: residual questions
2/25/17
David N Member
Q1. In Table 16-3 "Moisture-excluding effectiveness of various finishes" of the 2010 edition of Forest Products Lab's _Wood Handbook_ [WH] there are three columns labeled "1 day", "7 days" and "14 days" which are self-explanatory to most people, but do they mean "Coatings lose effectiveness as they dry?"
For example,
Q2. I have not found a reference[1][2] to the "rate" at which wood adsorbs/desorbs moisture from the surrounding air. Has that been quantified somewhere[3]?
[1] Although Ch. 4 of WH suggest changes in MC are "gradual", my experience with the large, thin cherry carving were that they can be "profound" over a wide enough area.
[2] Ch. 13 speaks of softwood stored under a "good pile roof" taking on moisture in terms of "% per month" (typ. 1-2%). The drying I experienced in my workroom was "% per hour," but once again, the "aspect ratio" of the piece was radically different from ordinary lumber.
[3] Not that it would help me any, given the unusual characteristics of the piece.
Going forward, if I am going to follow Hoadley's advice to "understand wood," I'll focus on Fig. 4-3 (attached) from the WH, and purchase, mill, and arrange the wood accordingly.
View higher quality, full size image (709 X 650)
Big Wall-art post
2/25/17       #2: First Big Wall-art: residual questi ...
The profound movement you witnessed may not have been completely from atmospheric changes, and finishes will not change those. It's a common technique when machining thick hardwood, that you remove the same amount of material from both faces. This exposes the same amount of core on both sides. Improperly dried stock can have a differential from skin to center. There can be case hardening and improper equalizing as well. You also used very wide stock, so that adds to the likelihood of kiln issues.
2/25/17       #3: First Big Wall-art: residual questi ...
Thicker woods can be reasawn into two thinner boards at times. Often this is common practice. This exposes the 'core' of the board suddenly to the world, as well as the outer surface already seen. This means you cannot use rich's otherwise good advice on machining equally from both sides. Your artwork also looks to be an exception.
When resawing, sometimes the two boards will separate - bow apart - in the act of sawing. This can be a strong force if the boards move inches, and can be hazardous. When this happens, it is a sign of a drying defect called case hardening. You can search for case hardening in Woodweb and Hoadley has this info. I will bet lunch this is the only serious problem you have with your piece, the other things being minor.
2/27/17       #4: First Big Wall-art: residual questi ...
David N Member
@rich c.
I paid no attention at all to even how much was being removed, let alone considering equalizing it on both sides. My obsession was keeping as much of the original 8/4 thickness as possible. I had, but whined about it, ripped the wide stock to make narrower planks before the glue up.
I do understand, now, that even sealing finishes only slow the rate of sorption, so I'm not going to be ignorantly making large thin works without some kind of mechanical support.
@David R Sochar
I'm coming round to the idea that the lumber was not kiln-dried. I will have a good talk with the vendors before I make any more purchases. And I'll pay particular attention to endgrain, which I completely ignored the first time. In particular, I'm going to find out if quartersawn is available to me: given the necessarily unequal state of the wood after the carving is done.
Thanks fellows.
2/27/17       #5: First Big Wall-art: residual questi ...
David,
You have made a major step in the right direction by getting Hoadley's book.
We all have to anticipate wood's reaction to all of the forces applied to it by us and the environment. It can be challenging for the most experienced craftsman to predict what's going to happen.
Good luck with your next project
