Adding Catalyst to Vinyl Sealer
11/18/19
dan shaf Member
Years ago I would shoot MLC vinyl sealer and then I would shoot my catalyzed topcoat. So why add in 1% catalyst? Their vinyl sealer hasn't changed, only the guideline or the suggestion to add in 1% catalyst. Is there something in the vinyl sealer that crosslinks?
11/19/19       #3: Adding Catalyst to Vinyl Sealer ...
mastercabman
It says that if you're going to use a post cat then you need to catalysed you vinyl primer/sealer with 1%
Don't need it if you're using a pre cat
11/19/19       #4: Adding Catalyst to Vinyl Sealer ...
Collin Parker  Member
Website: heritagewoodwright.com
I found it helps with dry time and sand ability, but not required and we get it in 5gal so kinda defeats the purpose of easily dropping the aaa wand into the bucket and pulling the trigger
11/29/19       #5: Adding Catalyst to Vinyl Sealer ...
dan shaf Member
"...but not required." That's the green light that I was looking for. But as a note of curiosity, what's in the vinyl sealer that the catalyst would react with? And it's only 1% catalyst added.
