Adhesives
Glue that becomes adhesive with moisture
2/2/14
Zac Hendricks Member
Hi, I am new to this forum. I am working on a project. I need to find either an adhesive that already exists or a formula that I can make.
This is what I need: An adhesive that will not be "sticky" until some moisture is applied to it. Then it becomes extremely adhesive.
I need it to be adhesive on plastic and/or rubber and/or wood.
Feedback would be much appreciated.
Thanks,
Zac
2/3/14       #2: Glue that becomes adhesive with moi ...
Polyurethane glues are typically moisture cure. The most common are like the Gorilla Glue brand.
I'm not aware of any that grab immediately as you are describing. Even the glues that are mixed with water have a pot life.
