Adhesives
spray adhesives containing methyl chloride - standard precautions?
9/23/14
gavin Member
I was wondering what type of precautions would be considered standard while using a spray adhesive containing methyl chloride? (in this case, the type that comes in a tank similar to a propane tank).
Where I work currently, there are no precautions. Is this normal? Will a half-mask with v.o.c. cartridges offer adequate protection?
I've read recently that the acceptable parts-per-million exposure of methyl chloride is far lower than solvents like acetone. This has me concerned, as I spray a fair amount of this stuff on a regular basis.
I can't find anything written which lays out the level of protection that I should be expecting in plain english.
Thanks.
9/24/14       #2: spray adhesives containing methyl c ...
Richalshel
Gavin,
If you look at the Threshold Limit Value published by the ACGIH it indicates that any concentration over 50 PPM for a time weighted average should require the use of a respirator. The OSHA permissible exposure limit is significantly higher, but ACGIH is more conservative in establishing its limits. The first step would be to determine what concentration you are dealing with when spraying, and then you can determine the minimum level of respiratory protection required. If you look at the NIOSH website for methyl chloride, they indicate a self contained breathing apparatus (SCBA) for use with methyl chloride until you know what concentration you are dealing with. Proper ventilation can go a long way to minimizing personal exposures.
9/24/14       #3: spray adhesives containing methyl c ...
Jeff Pitcher
Gavin,
You should consult the MSDS for the product. Your employer is required to have this on file and have it accessible to you. Chances are that you're not in compliance with OSHA at the very least. I would suggest looking at an alternative such as a water based contact cement. They are available in pressurized canisters and bulk as well.
