Adhesives
Fast bonding of 1/4" pieces?
1/2/16
Gerry Crumbley  Member
Website: http://www.grccreations.com
I've been asked to build some wood caddy boxes 13x7x4 approx. They want them out of 1/4" wood. (Craft type, poplar, ash,etc.).
Problem #1: having a hard time finding that cut of wood in bulk. They want 250-300 of these boxes by the end of January!
Problem #2: Even if I talk them into using Baltic Birch plywood, I need an "instant" bonding glue to put these things together. They do not want any nails to show. They want the corners 45*
I'm afraid that Hot Glue will ooze out and leave a clump along the joints.
What do you suggest? I see Loctite has a 2 part "instant" glue, but not sure if I can get it in bulk. (also the cost may be prohibitive).
1/4/16       #2: Fast bonding of 1/4" pieces? ...
If you tape/miter fold the boxes and use Titebond, just tape the last miter and set off to the side. No clamping. Pull the tape off in an hour. Any millwork house can resaw and sand the stock for you. No idea what a caddy box is, but with miter fold you should be able to easily do 80 boxes a day. So less than a week.
1/6/16       #3: Fast bonding of 1/4" pieces? ...
Ken Member
I would definitely use BB for the bottom. Rich is right on the assembly tape miter fold. Dado for the bottoms (hopefully) use PVA or PUR for adhesive and don't worry about squeeze out, just a quick hit on all sides to an edge sander.
1/8/16       #4: Fast bonding of 1/4" pieces? ...
A picture of what they wanted is at the website below. (The white 3 compartment box, on the left). It was from Crate & Barrel but is no longer available.
However, after further discussions the customer decided to go a different direction - end of project
thanks for your input!
White wood caddy
1/14/16       #5: Fast bonding of 1/4" pieces? ...
Ken Member
Gerry, I know the threads dead but did you ever discuss price?
1/18/16       #6: Fast bonding of 1/4" pieces? ...
Ken,
Yes - I came up with about $31-$32 ea if made with solid wood, and $23 out of plywood. Butt-joints, not 45's. This was figuring cost of material; cost to have CNC cut all pieces; cost of quick-set glue; 9 different glue joints - so, at least 10 min each to fabricate each; +sanding & staining (including cost of stain); and $35/hour labor.
Come to find out they paid $30 ea for the ones they bought from Crate & Barrel made in China.
