Adhesives
Adhesive that bonds UV coated Wood
3/6/19
Joshua Schmuck
Website: http://mccawcabinetry.houzz.com
Im trying to find a better way to bond 1/4" skins to UV plywood. Currently the guys are sanding the UV coating down and putting woodglue on there surely there is a faster Leaner way. like a glue that bonds to UV coatings?
4/5/19       #2: Adhesive that bonds UV coated Wood ...
Tyler
You could try a Melamine glue, they are made to glue to non porous surfaces. Otherwise polyurethane glue might do the trick.
4/5/19       #3: Adhesive that bonds UV coated Wood ...
Joshua Schmuck
ROO-GLUE guys works like a charm!!! no more sanding UV ply to skin with MDF! Just Glue and Go! bonds like Super Glue
4/6/19       #4: Adhesive that bonds UV coated Wood ...
Dave L
Just to clarify, melamine glue only works for gluing non-porous to porous surfaces and it cures relatively soft (not hard like cyanoacrylates).
