Adhesives
Contour bander glue options
11/5/20
Jimmy
Looking for advice for contour banding with PVC edge tape on melamine panels.
I currently use a Virutex PEB250+ handheld edgebander, and it does a nice job for us.
My issue is that using .5mm edge tapes, I inevitably end up with some degree of waviness in in the face of my edge tape. I'm fairly certain that this is a result of the thin tape heating up and very-slightly melting or softening up as it goes through the machine and glue is applied. I do not have the issue when running 1mm or thicker tapes.
I've tried tinkering with glue temps and quantities, but even running the bander at minimum temp (120 deg) and minimal glue needed to get good adhesion, I still get some waviness.
I'm currently running Jowatherm 282.2 glue pellets, but I'm open to changing that if anybody has advise on something that might help.
Thanks in advance for any pointers.
-Jimmy
11/8/20       #2: Contour bander glue options ...
I am not familiar with your bander but the over heating might be a result of the banding distorting before being pressed into the glue line. Have a look at the position of the banding with respect to the glue pot. Is the banding getting overheated there particularly when it is idle before starting on a piece?
You might be able to fashion a heat shield from sheet metal or fibreglass to prevent this.
11/21/20       #3: Contour bander glue options ...
Rusty Member
Jimmy,
How do you like the Virutex? I mostly edge band cabinet shelves, and have been using the wives iron and a laminate roller. Looking for something better, but do not want to invest in a full on edge bander at this point...
12/10/20       #4: Contour bander glue options ...
Jimmy
Rusty,
Yes, the Virutex does a nice job for us. The only issue has been the slight distorting of .5mm PVC edge tapes. It does a nice job with thicker PVC tapes and wood tapes.
I think the model I have, PEB250+, goes for $1700-$1800.
7/16/21       #5: Contour bander glue options ...
WorkTime Member
Website: https://www.worktime.com
I really like Virutex
