Adhesives
Glue spreader for solid wood glueups
12/11/20
Dave Edgerton  Member
Anyone have any pics of shop made glue spreaders for applying glue to strips of wood for panel glue? Don't want to send 1500$ on a few one? I mean a stationary spreader that you run the strip of wood on the roller.
12/12/20       #2: Glue spreader for solid wood glueup ...
Dave,
I am not sure what you have in mind or what you are looking for, but a glue spreader for veneer would probably do the trick, although I am not sure what the narrowest one would be.
Look at the Joewoodworker website , they have a section of glue spreaders,
Maybe something there will give you some ideas.
12/12/20       #3: Glue spreader for solid wood glueup ...
MarkB Member
May not work for a heavy production run but you might consider a multi-use approach like a pizzi with the appropriate accessory nozzle. Depending on how much you have to do it may be a less than perfect application compared to a roller spreader but serve a mile of other uses around the shop. We have two here and I havent picked up a full, partially full, or half empty, glue bottle in a long long time. We grabbed a pizzi at auction and then bought a clone from gluemachinery.
12/16/20       #4: Glue spreader for solid wood glueup ...
We have a $1500 roller glue spreader. It is at least 10 years old. So far that's $150 a year. We replace the felt on the roller periodically but besides that it works perfectly. Fast, easy, easy cleanup.
I think building one is not a great plan. If you glue enough wood to need one you should bite the bullet and buy one.
Good luck.
12/16/20       #5: Glue spreader for solid wood glueup ...
Bill what brand do youi have?
12/17/20       #6: Glue spreader for solid wood glueup ...
Its a Taylor, I don't think they make it any more according to their website.
There is a reduction drive for the roller and a secondary roller pushing on the main roller to moderate the glue. Not crazy complex but not something I would want to make myself.
12/29/20       #7: Glue spreader for solid wood glueup ...
Jim Sherrod Herron
I have four.
A JLT plate spreader
A JLT stile spreader
A Black Brothers 10 inch roller spreader and the Pizzi nozzle
I really only use the Ste spreader so I'd probably sell one of the others if interested.
1/13/21       #8: Glue spreader for solid wood glueup ...
AnthonySpringer Member
Where can I unsubscribe to find out the price? https://www.google.com/
