Adhesives
Clear Veneer tape Adhesive
9/23/21
Daniel Conway
Website: http://www.dccworks.com
I'm looking for a roll of 2" adhesive that acts as the adhesive for non preglue edging. I've had some in the past but can't seem to find it again. Its basically a roll of clearish glue with wax paper over top that can be ironed between your substrate and veneer. Does anyone have a resource for this matter?
Best,
DCC Works
"forest to table"
9/24/21       #2: Clear Veneer tape Adhesive ...
Fastcap. From Richelieu Hardware
9/24/21       #3: Clear Veneer tape Adhesive ...
Mark B
You can also buy their speed tape direct from FastCap.com
3M also makes a really impressive adhesive only double stick tape (peel one face, stick, peel the other, and all your left with is glue) but not sure about 2" widths.
9/24/21       #4: Clear Veneer tape Adhesive ...
Daniel Conway Member
We're looking for a tape that is heat sensitive so it only adheres when heated not stick on. Any leads on that?
9/24/21       #5: Clear Veneer tape Adhesive ...
Mark B
All tapes are heat sensitive. Are you looking for some sort of edge banding hot melt adhesive thats iron on?
9/24/21       #6: Clear Veneer tape Adhesive ...
we found this stuff and were going to give it a try. But yes iron on application. Trying to avoid peal and stick i.e fastcap https://www.hmtmfg.com/hot-melt-adhesives/advantage-hot-melt-adhesive-film.php
