Adhesives
What Adheres to UV Ply?
2/28/22
Steven
I need to put some 3/8" and/or 1/4" skins on 3/4" uv2s birch ply cabinet boxes. I was going to nail from inside, but since they are only 3/8" or 1/4" I wanted to use glue as well.
I know this question has been asked before, and I've used liquid nails in the past, but I'd prefer something not so thick so that the skins are flush with the face frame overhang. I wanted to see if there were glues/adhesives that others had used that worked well and ideally without having to scuff the uv coating.
Thanks in advance if anyone knows of anything else that hasn't been mentioned before.
2/28/22       #2: What Adheres to UV Ply? ...
Jared
Contact cement.
3/11/22       #3: What Adheres to UV Ply? ...
Dave Edgerton  Member
Nothing . Sand down to raw wood.
3/12/22       #4: What Adheres to UV Ply? ...
I've used Melamine glue. But you need to sand the UV coating with 100 grit and the other surface needs to me unfinished wood. The bond is good, not great.
